I'm in need of a Pioneer PD-91, CD Player Remote control (Part no. CU PD011)
Long shot I know, but if anyone knows where I can buy one, I'd be much obliged.
My System:
CDP - Pioneer PD-91
I'm Paul.
Robbie, You might want to research this further as I posed this same question a few years ago on the wam when I needed one, I believe (I may be wrong) but any remote from the same series might be OK, there's a couple on E-bay if you type in - pioneer remote control pd CD player - Can't guarantee they work. I am sure there is a list floating around on the net about Pioneer remote control compatibility.
Hope that helps.
HI-FI SYSTEM:-
Revox B250 Amp.
Revox PR 99 mk2 R2R.
Revox B126 C/D Player.
Yamaha GT2000 T/Table with Shure MKIV Cartridge and Jeco VN-45HE SAS/R Stylus.
Bang & Olufsen Beolab18's and the 19 Sub Speakers.
A/V 5.1 System :-
Soundsend Wisa box.
Harmen Kardon front and rear satellite.
Legend 10.2 Silverback Active Centre.
Thanks Paul, I've looked online and spotted other remotes that look similar, but as you say, might be worth me finding something about compatibility. The PD-91 remote, from the searching i've done, seems a bit of a rare thing.
If/when I do get another 91, I'd ideally like to have the remote with it as well. Have seen more than a few come up over the years, without remotes.
My System:
CDP - Pioneer PD-91
I'm Paul.
HI-FI SYSTEM:-
Revox B250 Amp.
A/V 5.1 System :-
Soundsend Wisa box.
