Results 1 to 10 of 18
Thread: Revox A77 rebuild
    I'm Allen.
    Default Revox A77 rebuild
    I now own 3 A77's and none of them work properly
    The latest purchase arrived 2 days ago , It's in lovely condition and was suposed to be in working order
    I plugged it in last night and switched it on , The power bulb filckered along with one VU meter bulb , Then nothing , dead as a dodo .
    Checked before switching on that it was on 240 volts Yes , Tested the external fuse OK
    Removed the case and tested the 2 internal fuse's both test OK
    Started haveing a look around inside with torch in hand and found this on the main power board
    52CFFDD3-08C2-48B6-858B-A50B50A000BF by , on Flickr
    Should look like this
    .182FA3BD-8CD4-4F21-B50F-004328EEF85A by , on Flickr
    Even that one look decidedly dud
    Decide to take the plunge and order a kit of parts to rebuild the boards all 7 also change the 3 big motor caps and some other bits , and the tape counter belt
    All ordered , I now sit and wait
    I'm inthescottishmafia.
    Should be well worth doing Al, be nice machines once they’re up and running.
    Hunter S Thompson
    I'm Allen.
    2 machines are 3.5 / 7.5 IPS and one is a ex studio 7.5 / 15 IPS
    I'm Allen.
    Nice, I’d be concentrating on the 15 ips. :-)
    Hunter S Thompson
    I'm Allen.
    If the one I am doing now works out OK I will have a go at the 15IPs model
    The Tandberg I have is a 7.5 machine and sounds great.
    Hunter S Thompson
    yes those pesky Evox Rifa caps are guaranteed to fail can be real smoke / stink bombs as well, the Frako's, phillips, rodestine and tants all have to be replaced
    The recap kits off Revox online are good as well Nichicon FC caps are nice for the Revox machines
    Good luck with your rebuild it can be vary rewarding
    I would recommend trying to fix what is wrong first if possible, then do the recap on a board at a time checking everything works each time.
    Alan
    I'm Allen.
    The new Sunstan caps arrived yesterday to replace the old Rifa Miniprint units
    De soldered the old ones 1 unit at a time and put the new ones in, Thinking " It should at least power up now "
    ANNNNNND Nothing
    Checked the plug fuse OK
    Checked the 2 internal fuses both OK
    Now what
    Time to have a read of the service book me think's , Although most of it will be like hyroglifics to me
    When you are powering up do you have any lights on at all Al?
    Is the back off ?, there are 2 pins in the back panel the make the continuity to the 240V power
    Alan
