Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Ortofon Cadenza Black - Fritz Geiger club
    Default Ortofon Cadenza Black - Fritz Geiger club
    Yes I know it's a limited club. Just one question, what tracking force are you using?
    I've been using 2.3-4g and whilst its extremely good, I still feel it's lacking something. I'm thinking 2.6g to mimic the tracking force needed for the MC ANNA?
    Just a thought, any advice greatly accepted.
    PRE
    I'm Peter.
    A personal piece of advice but I would not go above 2.3g. I’m not understanding why you would need a heaver tracking force.
    I’m not thinking this will improve matters.
    Other adjustments need to be checked prior to more downforce to confirm if all is in alignment.
    I'm Robert.
    Quote Originally Posted by Boyse6748 View Post
    +1, I'm also surprised you've gone that high. You've gone from the original CB recommended tracking of 2.3g right up to 4g
    Remember, it's been re-tipped with a different profile to the original Shibata so things are now different in regards to tracking force
    I'm tracking at around 2.15 / 2.16 and it's spot on.
    Here's Kilians response to me after I dropped the arm down on the record from a height and stressed the suspension, meaning i had to send it back.
    When i got it back I asked him if I should still track around 2.2 which is what he had recommended when I first had the re-tip.
    Hi Rob,
    yes, or 2.15 gram. 2.1 is more or less the lowest figure for optimal tracking and I usually don't have to go above 2.35 with these carts.
    Kind regards / met vriendelijke groet / mit freundlichen Grüssen,
    Kilian Bakker
    My System:
    CDP - Pioneer PD-91
    I'm Peter.
    Hi Rob,
    Kilian Bakker
    Spot on Robbie
    Something else is amiss. As you mention, I’m now concerned that the suspension may have been stressed playing at 4g....... I hope not!!!
    I'm inthescottishmafia.
    I think he means 2.3 to 2.4g.
    Hunter S Thompson
    I'm Peter.
    I hope so!
    I'm Robert.
    I hope so!
    Yeah, so do I
    My System:
    CDP - Pioneer PD-91
    I'm Peter.
    Anyway, if there is a miss understanding about the tracking force, my advice, for what it’s worth, would be to check VTA (SRA) and Azimuth to ensure all is as intended before increasing tracking force.
    This is a reasonably expensive bit of kit and care is needed but you don’t me to mention that fact.
    It might even be nice to know what arm / head shell is being used?
    I'm Robert.
    +1 you cant wing it with these sophisticated stylus profiles, said it til i'm tired
    I've had extensive experience with these, three different Ortofon Shibta carts, 2M Black, Quintet Black, Cadenza Black and now the FGS tip which is same as the Ortofon Replicants.
    ALL have required accurate set and a lot of attention in that regard, SRA/VTA overhang and Azimuth have to be bang on.
    They then have a very narrow sweet-spot which you have to find otherwise forget it, you wont hear what they do and are capable of and will think, what the $££$&# is the fuss about!?!.
    After paying mad attention to all parameters I've always finally dialled in that sweet-spot via careful on the fly vta, eventually bingo ! - happy days !
    It's why I'll never use a tonearm without on the fly, for this reason/these carts I'm drawn to and really enjoy.
    I'm seriously intrigued as to how you nail the sweet-spot otherwise, via tonearms that have vta adjustment slots ? or with anti-skate adjustment ? Either way, sounds like a bugger, not for me.
    You have to have patience and an ear too whilst doing it, it can take a while and be fatiguing but when you do, find it, hear it's there it's music and more and more music and ............... and hence I'm still up when I should be in bed
    * Btw, I've always found the above carts/ profiles nailed with a slightly tail down/negative rake AND when it's there/'in', the sound suddenly becomes calm, rather than noisy and tizzy, so listen, very carefully whilst adjusting - I should charge for this
    My System:
    CDP - Pioneer PD-91
    I'm jamie.
    its easy rob,i use a block of bronze between the tonearm mounting collar and underside of the tonearm bracket that the rest is fixed to. i then slip between feeler gauges and i can go up and down to my hearts content in finer tolerances than you 'on the fly' guys dream about
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
