Results 1 to 10 of 13
Thread: ZeroStat Gun - do they work?
    I'm Russell.
    Default ZeroStat Gun - do they work?
    Getting a bit of static on my Clearaudio Emotion TT as not using any mat on the acrylic platter.
    Anybody use a ZeroStat - are they any good?
    Yes, they help. As do anti static inners
    I'm Russell.
    Thanks Grant.
    My TT (Clearaudio BlueMotion) is grounded at the centre bearing / spindle as well as arm.
    I don’t hear static through the cartridge but when I come to take the record of the platter you can feel the force of the static that’s built up as well as the crackling etc.
    I use Nagaoka sleeves and also clean records using the Disco-AntiStat system as well as a carbon brush before I spin them.
    I'm John.
    I've found this brush to be very effective and better than the Zerostat.
    https://www.amazon.co.uk/Nobsound-Tu.../dp/B07D29X94S
    Sent by me using an appendage
    SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    I'm Charlie.
    NOo need to use one, if you wet clean your record on a RCM
    R2R: Studer A820 1/2 inch 2 track; Otari MTR-12 1/4 inch 2 track; Sony APR 5003; Sony APR 5002; Studer A807/II. Vinyl: Platine Verdier Allaerts MC1B/Schroeder Reference & Model 2 Decca C4E/Hadcock 228 TRON Seven Reference phono. Keith Monks MkII RCM Other analogue source: Nakamichi Dragon with ANT4066 mods. Amplification: TRON Meteor preamp TRON Voyager 20B SET power. Speakers: Avantgarde Duo. Digital: computing at last with Prism Sound Lyra 2 A2D converter
    I always statted my records after I washed them.
    I had another beside tt but wasn't used so much
    I just use a Decca carbon fibre record brush. I don't use any aftermarket platter mat (though I have tried a few), and simply rely on the manufacturer's rubber mat.
    I rarely got problems with static, and now I don't have any at all - once I realised that one should touch the metal work of the TT with one hand, whilst holding and using the record brush in the other.
    Having a frequently watered pot plant near your TT can help with static problems.
    I'm Paul.
    In what way ?
    Genuine question, like to know more.
    The increased local humidity of the air in the vacinity of the TT will help neutralise the static. It's not a guaranteed solution, but can work in some situations.
    I'm Paul.
    Thanks, will give this a try.
