Results 41 to 45 of 45
Thread: RCM cleaning solutions - current
  1. #41
    I'm Adrian.
    Quote Originally Posted by speedyj View Post
    Decided to try an ultrasonic. This seems like a good buy from Amazon.[IMG]
    Be here tomorrow so i'll have a play and get back to you all.
    [/IMG]
    Hi Steve,
    I will be very interested in how you find it, I notice they also do a 10 record version, I might be tempted myself depending on how you find it.
    Cheers
    Adrian
  2. #42
    I'm John.
    The ultrasonic cleaner just arrived. Very well packed in a big double box.
    Not used it yet but set it up and I have to say the build quality seems top notch. Instructions are clear and easy to follow and all parts fit perfectly when assembled.
    I'll have a good session with it tomorrow as I have the house to myself for most of the day.
    So thats a play records louder than normal whilst cleaning a pile of new ones day.....................perfect Saturday.
    [IMG][/IMG]
    [IMG][/IMG]
    Home built PC driving Adam Audio 7 Active Monitors from Asus Xonar Essence STX.
  3. #43
    I'm John.
    OK so tried it today and it works really well. Much quieter than I expected and very easy to operate.
    I couldn't do much though as I need some more distilled water to make some more cleaning solution.
    Tthats on order from Amazon for tomorrow so I'll have proper session then and report back. Might even do a little vedeo if you like.
  4. #44
    I'm Adrian.
    I would be very interested in how successful you find the cleaning, so say you listen to a record first noting clicks/pops, background noise and then put it through the cleaner and then re-listen and report on any improvements, it would be nice to see a video of it in use. Thanks.
    By the way what cleaning solution are you using?
  5. #45
    I'm John.
    I use my own solution .
    800ml distilled water
    200ml IPA
    5ml wetting agent
