Results 1 to 4 of 4
Thread: FS: MBL 7006 Integrated Amplifier - Immaculate
    I'm Russell.
    Default FS: MBL 7006 Integrated Amplifier - Immaculate
    Can’t believe I’m doing this but it’s time to let the wonderful MBL go to pastures new.
    I’m the second owner of this piece of aural and visual art and I genuinely cannot see a mark on it.
    Finish : Piano Black / Gold
    Original boxes and packaging
    Upgrade MBL full aluminium remote control
    User Manual
    Mains Cable
    Retailed at £6k when new
    Benefits from the upgraded full function aluminium remote control, and has a very high end headphone amplifier built in.
    Sound is quite wonderfully organic, with immense presence and fluidity - very three dimensional sounding amplifier - a rare find on the pre-owned market for sure.
    What the manufacturer says :
    The MBL 7006 is an excellent choice for music enthusiasts seeking a compact integrated amplifier. Produced with know-how and a passion for detail, its technical qualities, solid workmanship and attractive design makes the 7006 first choice for music lovers who want maximum listening enjoyment at manageable costs. Its exquisite visual appeal is matched by sophisticated engineering that puts it in the genuine high-end range of the market.
    The MBL 7006 integrated amplifier is rated at 180 watts per channel but uses the same circuits as the MBL 8006 B amplifier and 4006 preamplifier combo that has a great ability to drive low sensitivity speakers.
    The clarity and precision of sound will blow the minds of listeners.
    The amplifier has unbelievably clear, detailed and vivid sound. It lends power and natural quality to the music as never before experienced in this class. With the signature MBL's warm, rich and and dynamic characteristics, other solid state amplifiers pale in comparison to the MBL 7006. Usually only tube amplifiers can give rich sounds, but the MBL 7006 takes that a step further, surpassing them in dynamism and bass control that will even surprise the tube lovers of the world.
    SPECIFICATIONS
    Inputs............................................ ..6 inputs
    ..............................................1 x XLR, 2 x CD, 2 x high level, 1 x processor
    Outputs........................................... Fixed out, Headphone Out (front panel)
    Frequency Range............................DC - 400kHz
    Output Level....................................1 Veff to 10 Veff max
    Output Impedance...........................100 ohms
    Noise Distortion...............................<0.001%
    Input Sensitivity................................315mV
    Signal to Noise.................................98/101dB, 1V/25 ohms
    ....................................CD: 103/107dB, 1V/25 ohms
    Input Impedance...............................High level: 50k ohms
    ...................................Bypass: 10k ohms
    ....................................CD: 10k ohms
    Power Section
    Rated Power....................................120 watts (8 ohms)
    ........................................185 watts (4 ohms)
    Output Voltage.................................35V max
    Output Current.................................20A max
    Input Sensitivity................................1.5V, 185 watts, 4 ohms
    Channel Separation..........................90dB
    Signal-to-Noise Ratio........................Unweighted: 111dB
    .........................A-weighted: 115dB
    Frequency Response........................DC - 135kHz / -3 dB
    Total Harmonic Distortion + Noise......<0.006%, 4 ohms, 1 kHz, 50 watts
    Damping Factor................................300 at 4 ohms
    Power Consumption..........................4VA, sleep mode
    ..........................120VA, idle mode
    ..........................450VA, maximum
    Line Voltage......................................230 Vac 50/60 Hz (single voltage)
    ....................................115 Vac, 50/60 Hz
    Dimensions(w x d x h).......................45 x 41 x 12 cm
    Weight............................................ ...15kg
    Looking for £1950 collected from Conington, Cambridge or will send out at buyers cost / responsibility as still have original packaging etc.
    Wow
    Very classy Russell.
    GLWTS
    I'm Russell.
    Quote Originally Posted by andyrlb View Post
    Wow
    GLWTS
    Cheers Andy, yes it certainly is a lovely looking thing and it doesn't sound too bad either ;o)
    Would you believe this is their 'entry' level amp at circa £6k!!
    I'm Russell.
    Now sold
