Results 1 to 10 of 13
Thread: Reducing the output of a passive pre-amp
    Default Reducing the output of a passive pre-amp
    Hi
    I have a simple Axiom Signature passive and the output is far too high for my needs. So I would like to reduce it by say 15db. You will see from my questions that, although I can wield a soldering iron, I am no electronics expert
    Can I achieve this by:
    1. Replacing the existing 1.2K resistors with higher values - if so what?
    2. Putting additional resistors elsewhere in the unit. If so where and what values?
    Thanks in advance
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    I'm Lee.
    What's the value of the pot?
    Cheers Lee
    Quote Originally Posted by lilolee View Post
    Its a Noble 10Kohm pot. At the moment I can get reasonable volume with the pot fully turned off and a movement of maybe 1mm is good listening level and 2mm just too loud. I am running an experiment of a 1000wpc amp into 100db sensitive speakers (dont ask!). Sounding pretty good but need more volume adjustment to be sure.
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    I'm Lee.
    Either 27k or 33k will give you about 15dB.
    Cheers Lee
    Excellent. If its not giving you a leading question, where do I stick them. I'm guessing in the left and right wires that join the input phonos with the volume control. Or is it in place of the Caddock resistors?
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    So where do I stick them. I'm guessing in the left and right wires that join the input phonos with the volume control. Or is it in place of the Caddock resistors?
    Itching to order a couple of suitable resistors, so can anybody answer this question?
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    I'm Dennis.
    Painting the hall through the letterbox anyone?
    Yes between input and volume pot.
    Thanks Alan
    Can I just ask is a 33K resistor what they call 3.3R?
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    3.3r is 3.3 ohms.. you need 33kohm...or am i getting old
    you want 3 orange bands..
