Results 11 to 20 of 23
Thread: Audio Note Push Pull and Tannoys
    Quote Originally Posted by WESTLOWER View Post
    I’ll say it again
    Radford STA25 will fit your criteria!!
    You won't do better than a Radford sta 25 with these speakers. If you heard Westlower's you wouldn't even be asking the question! It's not as simple as valve versus solid state with these Tannoys. Too much damping-Class D, solid state-and they clam up. Too little damping-too low damping factor and /or feedback-and the bass will disappear like a toilet roll in Tesco's during lockdown. So you need push pull, running Class AB, with the right damping factor for these speakers to show their best. There are solid state amps that will do the job, but they won't better the Radford /Tannoy combo
    Quote Originally Posted by AD Audio View Post
    If a valve amp is not a practical proposition, please can you let us know what solid state amps will do the job? New or secondhand.
    Cheers
    Mike
    Mike.
    I'm Phil.
    How does one get a Radford these days ?
    Eric Bibb
    Quote Originally Posted by hifinutt View Post
    Drop Will at Radford Revival an email is the way to do it.
    I'm Michael.
    I'm Phil.
    thanks guys
    Eric Bibb
    I'm paul.
    Quote Originally Posted by Opti-cal View Post
    I think you can be more likely to end up with the 'wooly' bass as described trying to pair valve amps and speakers. It's something SS (in my experience) is more forgiving of. BUT, get the right valve amp AND the right speakers (synergy!) and you can achieve floor shattering bass which to my ears can sound more organic than SS. My 300b SET in parallel configuration paired with my Cambridge Acoustic Grand Master's could crack the paint on the walls.
    Quantity of bass should not be confused with quality of bass. Until recently I had not heard the quality my Lii audio crystal 10 can do driven by my Bakoon 11r.
    Quote Originally Posted by paulf-2007 View Post
    Oh yes absolutely agreed there, however to me its quite obvious if you simply have 'quantity' without 'quality', it sounds absolutely awful. Often culminating in one note boom which smears so much of the rest of the frequency range the speakers are attempting to deliver.
    When its dialed in properly you should be able to detect bass guitar plucks maybe 10-15hz apart.
    I've always lusted after some Bakoon stuff incidentally. Always look as interesting as I'm sure they sound (never actually heard any) . . . .
    The puresound 2a3 which I use is said to be really good with big Tannoys, I've not heard it myself though.
    But it's an 18w push pull amp with plenty of grunt.
    Chris
    I'm Shaun.
    I have only just solved a similar issue. I was using a PrimaLuna pre/power combo running EL34's at a max of 40 Watts per channel into KEF R5's and there was just so little grunt or slam. The problem was immediately solved by switching to an Usher R1.5 power amp. I now have all of the grunt and slam I could want.
