Slight change in requirements on the Vitavox S2 screw on adapters.
The customer's original idea of a walnut ring did not plan out, so 2 rings in brass were made that bolt to the adapters (now look much more like the usual screw on aluminium adapters - this allows for throat alignment and tightening of the bolts).
The brass rings are secured to the horns by 4 countersunk wood screws.
Fun turning project.
Sent from my Pixel XL using Tapatalk
