Results 1 to 10 of 13
Thread: Beyerdynamic DTX 900 foam earpads
    Default Beyerdynamic DTX 900 foam earpads
    I really like my Beyerdynamic DTX 900 headphones, but the earpads are wearing out - and are generally a lot worse for wear. Is it possible to replace these easily, or do I have to assign these headphones (sadly) to the junk drawer, and replace them with something similar or better?
    If the latter, what would be a good recommendation - up to (say) £150.
    In the first instance I'd like to get these fixed, if possible - the units are still working well.
    Dave
    Dave, I bought some beyerdynamic dt990 pro a while back, I dont normally like headphones but these are great, around £105 if you cant get yours fixed
    I'm Pete.
    just looked on google there are a great many suppliers for the dtx900... as an example
    https://www.aliexpress.com/i/4000157...5d671657800-43
    I'm Gary.
    Pete,
    your still truckin!
    remember you from back in the day on the old forums, and they say nostalgia ain't what it used to be.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I remember a picture of some sort of monster or weird cat like creature years ago on some forums, was that Zanash?
    I'm Gary.
    That was the Guy...
    very knowledgeable and helpful, knew a lot of things about a lot of things.
    Helped me out a few times back in the day.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    That was the Guy...
    Great to have him still around I remember reading lots of his posts in the past when I was doing my hi-fi research on the internet.
    Thanks for the suggestion. Are these open or closed type?
    I have ordered some cushions, but they'll take a while and I don't know if they'll actually fit easily or be any good. I might buy the DT990 Pros suggested while I wait!
    Are there any other good headphones in the price range I suggested? The top seller on Thomann.de seems to be the Beyerdynamic DT770 but it's not necessarily the best just because it's popular.
    Dave
    Open,
    A quckie re the DT990 - which now seems cheapest at Thomann.de. This appears to have a coiled lead - is that normal nowadays, and are such coils a good idea? I think I've had both straight and coiled leads in the past - my current phones are either wireless or have straight leads.
    Probably not a deal breaker, but I thought I'd ask. If there's a choice (which there may not be) which would be better - or probably just "depends"?
    Dave
