Cheers for the tea and sympathy guys, my chin is up though, in fact both of them are Doesn't do to dwell on mistakes, that kind of distraction just sets you up for more mistakes! You're probably right Grant, maybe my "work head" wasn't screwed on properly due to inactivity.
Another bright and sunny morning, and Alexa says it's currently 14C, with an expected high of 24C. Not sure if it's too breezy to sit outside, but I have devised a method to determine the windiness. I put an opened bag of crisps on the garden table then go inside to make a cup of coffee. If I return to find the crisps all over the garden then it's too windy.
I know what your thinking - with all the windy weather we've been having it could get expensive, but by switching from Walker's to Morrisons own brand crisps, I'm making substantial savings. I'm not as daft as I look, see
I suspect results will vary with the brand of crisp. A heavier crisp, such as McCoy's, will be less susceptible to higher windspeeds, whereas a light crisp, say Discos, far more so.
Do they still make Discos? Not seen them in years. Not that I'm bothered, never liked them anyway. A girl's crisp.
You also need to study the effect of wind shear on the shape of the crisp, I'd theorise that a square crisp would offer more resistance to wind and therefore be more affected. And then you need to compare crinkle-cut to smooth.
I like crisps.
Could you get away with using Twiglets?
