Results 1 to 4 of 4
Thread: Help wanted with Wadia 381 Cd player
    I'm Robert.
    Default Help wanted with Wadia 381 Cd player
    Hi all.
    Anybody know where the power supply fuses are on a Wadia 381 cd player? I have looked around the mains entry but cannot see anything like a fuse Wadia says there are two inside. Do I need to take both the bottom cover and top cover off to find them?
    I am looking to upgrade the fuses hence trying to find them.Regards Robert.
    follow the mains run... maybe in the black box at side. there is one on the main board
    I'm Tony.
    Usually the fuses are in the Shaffner IEC, above the upside iec entrance, they is a little notch that needs levering with a small flat balded driver, pop this open and the fuses will appear
    Coherent Systems
    Real high end sound with musicality not hifi
    I'm Robert.
    Thanks for help. The two fuses are just above the main ac inlet a little difficult to see when in rack.
    Thanks to all Regards Robert.
