HELP HELP , can anyone recommend a set of good quality Z plugs for a pair of Pulk audio speaker cables I have
I can then attempt to fit them
I'm Allen.
Here you go Al, very easy to fit as they are screw terminated.
https://www.ebay.co.uk/itm/Divine-Au...wAAOSwnHZYkJVa
I'm Allen.
I often use similar. Yes, the covers screw on.
I'm Allen.
normally al,they screw on from the front.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Connect cable and then the covers screw on from the plug end.
I'm Allen.
OK thanks , the cable ends look like this
C01569AA-D266-4910-9C98-6DCACAFFDADF by , on Flickr
Those Litz speaker cables are worth more if left as they are and unmolested. They are now quite sought after and can fetch a few bob. They were made in Japan, but also marketed here by Monitor audio and I believe Monster in the late seventies. The sound quality can be remarkably good in the right system, but they can present a tricky load for some amplifiers. I've owned a couple of sets of these.
I'm Allen.
