Results 1 to 10 of 10
Thread: Wanted pair of 20mm slow blow 6.3 amp fuses, would consider 5 amp.
    Default Wanted pair of 20mm slow blow 6.3 amp fuses, would consider 5 amp.
    Im after a pair of 20mm T6.3A fuses but would consider T5A.
    I would ideally like Synergistic research black or blue but open to others as long as I can match.
    I'm Adam.
    Sorry, but fuse values aren’t really open to random change or “would consider”. If you need 6.3A, you need 6.3A.
    Please don’t turn my wtd thread into any sort of fuse debate or educational public broadcast.
    Thank you
    I'm Adam.
    My apologies for attempting to introduce the concept of basic electrical safety rules into your thread.
    Please forgive me. As you were...
    I'm charles.
    Hi Martin,
    I sent you a PM to avoid posts like the one above
    I'm Patrick.
    You can avoid common sense if you like (many seem to these days) but Adam is absolutely correct.
    Quote Originally Posted by Patrick Dixon View Post
    Adam has no idea how I intend to use these fuses as I’ve not offered any information to that effect.
    This is a wanted advert , I’m not asking for fuse advice , safety efficacy or otherwise.
    I’ve asked nicely to refrain from derailing my wanted advert, please don’t make me trouble the moderators.
    There would be a safety issue if a higher rated fuse was being considered, but it's not - Discopants is considering fitting a lower current rated fuse, so if anything, the 5A fuse may blow more often.
    Good post Barry......Only reply to the post if you have something suitable for Martin....The thread is a mess...I hope something suitable turns up Martin...
    'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
    Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
    Bump , if anyone has a single SR blue T6.3A that could work too.
