Results 1 to 10 of 11
Thread: Happy accident, switched off the LED lighting circuit....
    I'm Tony.
    Default Happy accident, switched off the LED lighting circuit....
    Switched off my lighting ring today to replace an LED downlight.
    Left it switched off while I had a cuppa and forgot my task, getting old!
    Sat down to listen to a few chunes and thought WOW the system is sounding very good today!
    And then it dawned on me!
    I simply can't believe how much noise my lighting system is introducing into the mains.
    I have LED downlighters throughout all the ceiling lights with a few Hive bulbs thrown in (networked lightbulbs).
    Not sure which is noisey but the effect is similar to when I had noise due to network plugs, that I threw in the bin!
    I'm guessing that it may be the Hive bulbs, so will be removing them when I finnish this listenting session.
    Love a free tweak and the improvement is considerable. Much improved depth, slam and sweetness...
    VPI Scout 1.1, Hana ML, Vanderveen MC10 SUT, WAD Phono3, Rpi3B+/Digione Signature, Xiang Sheng DAC-01, WAD KiT6550 and Reiver Edingdale SR
    I'm Allen.
    You better order some candles
    I'm Tony.
    Well its not the Hive bulbs
    Might be the downlighters or maybe a dimmer switch...
    Might install a dedicated mains at some point.
    Yes - best to install a dedicated mains. And use a completely separate RCBO, and not a 'spare way' in the consumer unit.
    I'm Dennis.
    No no no, under high bass transients the flame will flutter about and you know the noise that makes.
    'Candle In The Wind'
    I could wax lyrical about the sonic benefits of candles, but I don't want to get on your wick.
    I'm Andre.
    I'm Stewart.
    If it sounds that good you might end up burning the candle at both ends.
    I'm Greg.
    Quote Originally Posted by legb4rsk View Post
    Have a blow out and turn the wick up. You know it makes incense!
    Analogue: Thorens TD 124/II - SME M2-9R - Ortofon SPU Wood A - Sculpture A Mini Nano
    Digital: Roon Nucleus - Limetree Network
    Amplifier: Naim NAIT 50
    Speakers: TBC
