Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Balanced DCB1
    I'm Dominic.
    H
    Quote Originally Posted by grog View Post
    awesome looking build, what was the incentive to go balanced?
    i have the same board running SE, with a relay stepped attenuator,
    if it's for non audio and low power, i use these, https://cpc.farnell.com/myrra/47152/...reg/dp/TF01429
    Thanks for suggestion, they look perfect.
    Going balanced was partly just curiosity. My mono blocks are next to the speakers with the other components off to one side. It all worked ok, but did need 4.5m long interconnect cables and I wondered if these might work better balanced.
    Quote Originally Posted by Domg View Post
    H
    I use a pair of monoblock power amplifiers, each located directly behind the speakers (so the speaker cables are about 30cm in length). The monoblocks have balanced-line inputs and are connected to the preamplifier (which has true dual differential balanced outputs) via 15m of balanced-line cable running under the floor.
    Works for me, so I would recommend you try it out in your system Dominic.
    A preamplifier.
    With no overall gain?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    Amazing build quality. Just goes to show what can be done in your garden shed!!!!
    PRE
    Yes, zero gain. Which granted means it isn't technically a pre-amplifier, it's a buffer. But it's the common terminology.
    I'd probably strictly call it an attenuated buffer. Or a buffered attenuator
    Well whatever it is it's an outstanding bit of kit. The best 'Thing that goes in front of the power amplifier and lets you change the volume' I've ever had.
