Results 11 to 20 of 23
Thread: Speakers advice please
    I'm Rohan.
    Normally you'd pick the speakers to match the room and then the best amplifier that can drive them with the sound you like in your budget.
    What size room have you got?
    Lawrence is spot on. If you have a connection with the DM2 (which I quite understand, as I have a pair myself), don't let the amp determine their fate. Speaker choice is a very personal thing- generally amps come second in the great hifi hierarchy....I'd be more inclined to swap amps.
    Also, in this time of isolation, amp-swapping is far more possible!
    https://r.tapatalk.com/shareLink/top...ink_source=app
    If he decides again to sell these, then nab them if u can.
    Great, neutral, easy to drive big gala and will be OK in a smallish room I'm sure, even tho they are big
    I'm Nigel.
    I agree with Grant. I use a pair in a small listening room and they work very well indeed, plus Nathan is just up the road in Yate.
    Quote Originally Posted by VanDerGraaf View Post
    Forgot to mention I've had 3 pairs in the past They were probably my favourite vintage speakers of that period, better than any Kefs I tried, but then I've never owned BC1s, Rogers monitors etc.
    Actually if you like DM2s that might be the road to go on. What were those bigger Rogers ones LS something, I forget the model, but well worth buying if you can find a pair (might be a bit above the budget though).
    I'm Julie.
    They do look beautiful someone knows the specs? I looked online but couldn't find it :-(
    I'm Julie.
    I love the Dm2s but lacking a bit on the bass for me and I would like more of an open sound
    Quote Originally Posted by Julie8113 View Post
    If that's the ones I mentioned they are super efficient and even a little t amp, or a valve set amp will drive them well. Think sensitivity is about 96db
    I'm Julie.
    This is where my understand of speakers is limited - I don't fully know what sensitivity means. I understand wattage
    They don't need many Watts to drive them loudly. They will get too loud long before your amp runs out of power.
    A QUAD 606 would drive Edingdales no problem at all. They are very sensitive/efficient and an easy load.
