Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Capacitor/resistor
    I'm Vince.
    Default Capacitor/resistor
    Hi, I'm looking for some advice as well as the actual components.
    I have a pair of Silver Iris tweeters that I wish to add to my existing speakers. I'm not changing my current speakers, merely adding the Iris's to see if it adds or subtracts, soundwise.
    I want to simply add them by connecting with a positive and negative cable to each input from my speaker terminals. Basically the same if I was adding supertweeters and I want something to filter out the mid bass
    Frequency's below 2.5khz. I just want something I can run inline on the connecting cables. The crossover of my speakers is 2.8kh, but I want to go a little lower.
    Anyone got a good make of what I need or can tell me what I need.
    Thanks in advance and stay healthy.
    Vince
    I'm inthescottishmafia.
    8uF will get you to 2.5khz high pass.
    I use Miflex on the tweeters in my Bastanis, I like them-
    https://www.hificollective.co.uk/cat...capacitor.html
    Hunter S Thompson
    Not cheap mind!
    Hunter S Thompson
    Not cheap mind!
    Ouch!
    If they are too rich, this might help you decide-
    http://www.humblehomemadehifi.com/Cap.html
    Trouble is that large a value in a poly will not be cheap..
    Hunter S Thompson
    Sorry, forgot to say that value is assuming an 8ohm tweeter.
    Hunter S Thompson
    I seem to recall Goodmans using 8uF in a 3kHz filter. Not that it makes much odds at 6db/oct. Maybe they just wanted the roll-in late.
    It may well have been depending on the impedance of the driver, but as you say, not much odds at 6db/Oct.
    Hunter S Thompson
    I'm Ian.
    what about cheap motor run polyprops to test the concept ? before going the whole hog ?
    Yep not a bad idea. The maths are the maths though, so if the OP is sure of the frequency and the tweeter is 8 ohm nominal, 8uf is correct.
    Hunter S Thompson
