Results 1 to 10 of 12
Thread: Triangle Antal EZ
    I'm Kevin.
    Default Triangle Antal EZ
    Has anybody run a pair of these?
    If so, I am wondering what you use as amplification for them?
    Kevin
    I'm Neil.
    I know the previous version well, the EX. They work well with valves, if the amp is about 50 watts + and has good driving ability. These need breathing space to work properly.
    Regards Neil
    I'm Francois.
    I used to have a pair of these driven by an Icon Audio 40, and the result was very nice indeed. Plenty of detail and good depth of soundstage. As far as I remember they are a little fussy about placement, and require some testing, but once done, they offered a very nice, even picture of the musical scene.
    I now run their little brothers the Comete, and even with a measly 12W they rock my small office.
    Enjoy!
    Francois, Bergerac, France
    Source component/s:
    Musical Fidelity M1 Dac, Allo Digi One, Sony SCD-XE800, AVID Ingenium Twin arm, Audio Note Arm One, Groovemaster II 12in, Audio Note IQ3 MM, Denon DL103R MC, Croft Basic 25, TQ Iridium Phonostage, Puresound T10 Stepup Transformer, Zavfino majestic tonearm cable
    Amplification:
    Audio Note OTO PP, Dussun V6i
    Loudspeakers:
    Triangle Comete ES, Klispch RP600M
    Cables/stands:
    Quadraspire, Belden 9497
    I'm Kevin.
    Thanks guys. Current amp in the system is 40W into 8 ohm and and 70W into 4 ohm.
    I think it should be sufficient for the levels I listen at in my room.
    If someone would buy my Firebottle monos, I can sell my Modulus 86 Amps and upgrade to a 286 or 686.
    That should be sufficient.
    Kevin
    I'm Kevin.
    I have ordered the speakers. I hope that they will be delivered this week.
    Kevin
    I'm Russell.
    I had some Antal MK I Floorstanders last year and thought they were fantastic for the money.
    Hope you have a great fun with them when they arrive.
    What did you drive them with Russell?
    I'm Russell.
    Tried them with several from my Rotel RA01 to my Ming Da to my MBL 7006.
    Thought they sounded best on the end of the Crayon amp I had.
    I'm Kevin.
    Kevin
    I'm Timothy.
    Very nice! Enjoy!
    Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
    Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
