Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: This Device is phase-inverting
    Neither could I when I tried it. One less thing to worry about.
    I'm Evie.
    Conrad Johnson are hot on this topic and have a doctrine of 'absolute phase'. I could never tell the difference but I did it all the same, I.e. I swapped black and red on my speakers. If anyone can tell the difference on a blind test (consistently), then I may reevaluate my position and believe rather than subscribe on the off-chance.
    For what it's worth, here were my thoughts on the matter: https://theartofsound.net/forum/show...Absolute+phase (ignore the second part of the post).
    Well agree with your findings Barry , I appreciate your help , stay safe
    NO NO NO>
    It's an unbalanced signal, otherwise known as single ended, If you swap the signal wires you connect the screen to the 'hot'.
    Swapping the speaker wires over is different and perfectly OK.
    Thanks. I think it would depend on the circuit - but you're right in this case I'm sure. So stick with the loudspeaker cable swaps - which should avoid any problems.
    Dave
    I'm Phil.
    I just noticed audionote M-one pre amps are phase inverting , slightly puts me off them but from what i gather from this thread , it makes little difference
    from the blurb
    Audio Note (UK) M1 Line Pre Amplifier is a pure Class A, Zero Negative Feedback design, employing a single ECC82 dual triode valve.
    It has been specifically engineered for sonic performance rather than technical specification, and offers an outstanding level of performance and value.
    It fulfils all Audio Note (UK) Level 1 criteria: -
    Pure Class A operation
    Zero negative feedback
    Materials and component quality
    The M1 Line and M1 Phono are phase inverting.
    https://www.audionote.co.uk/m1
    Eric Bibb
    It won't make a huge diffrence phil, and you can always swap the negative, and positive leads around on the speakers, to see which you prefer.
    Much of the equipment out there inverts the signal, they just don't advertise the fact!
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
    I'm Phil.
    Thanks , as far as I can see only the m1 and m2 are phase inverting , the m3 seems not , am I right in this ?
    Eric Bibb
    I'm Philip.
    I've been curious about this as I'm about to start refreshing a Quad 405-1 and I know it is phase inverting as standard . Used with a Quad pre amp that would of course right itself. Some of the mods for this change it to non-inverting and I wasn't sure if it was necessary. Sounds like it isn't...
    Never underestimate the power of stupid people in large numbers...
    I'm Rob.
    Some Class D amps are phase inverting and I can hear a definite change when swapping RED for BLACK speaker cables.
    https://youtu.be/ZCBe7-6rw4M
