Results 1 to 10 of 18
Thread: Breeze Audio Sabre Dac/Pre
    Default Breeze Audio Sabre Dac/Pre
    Nice sounding dac/pre with balanced and unbalanced outs and digital volume control. It has fast and slow filler settings for a subtle change to the sound.
    It uses the superior ESS Sabre ES9018 chip, not the cheaper K2M low power type designed for mobile devices that you often see in DACs. It has twin transformers for digital and analogue sections. I spotted some Nichicon caps in there too.
    The volume control is digital but uses ESS' "bit perfect" technology rather than the usual digital attenuation that reduces bit rate and resolution at lower volumes. I don't understand it but I know it sounds nice when used as a pre amp straight into a power amp.
    It's in a champagne colour but there are a few small nicks to the top edge and a scratch on the screen.
    I'm only asking £125 collected for this plus postage at cost.
    I'm Phil.
    very nice , how do you control the volume then ?
    Eric Bibb
    I'm Rob.
    There should be a remote control.
    https://youtu.be/ZCBe7-6rw4M
    This doesn't have remote, there are up and down buttons on the front. Tricky to pick up on the background but they say up, down and menu. Menu is quick press to change source, long press to change filter.
    Just to add you can try a bit of op amp rolling with this it has sockets.
    I changed the op amps and it sounds really natural and analogue now. Haven't heard a Sabre Dac that sounds as nice as this, they're not normally my cup of tea. Can't include the new op amps at the price (there's 6 of them!) but open to discussion.
    Might as well put this on hold and enjoy the beautiful sound it produces until things get back to normal.
    Ok, 6 DACs is clearly too many for one man, so it's back up for sale, postage only at the moment obviously.
    I think £125 is a bargain for a weighty Sabre dac/pre with a 2 transformer power supply, digital volume and fast/slow roll off filters.
    Actually I've just worked out I've got 8 dacs. Not including a little one that plugs straight on the computer for headphones (like a Chinese dragonfly)
    Bump
