Hi all
I will soon be building a new full set of Interconnects and will be using the Van Damme Shotgun Cable throughout and that has a 6mm outer diameter
My usual supplier of the type of plug I used in the past has ceased trading so I am looking for recomendations for a good quality plug to use
Anyone got any recomendations for a plug that will fit a 6mm OD cable
Been on the BayofEvil and found a few that look ok, any thoughts on these
https://www.ebay.co.uk/itm/4-Gold-Plate ... 1398906510
https://www.ebay.co.uk/itm/NEUTRIK-PHON ... 0603457781
https://www.ebay.co.uk/itm/4pcs-RCA-Mal ... 3949843047
Thanks for any help with this
Paul
