Results 1 to 10 of 18
Thread: Wanted: Inexpensive MC head amp or SUT
    I'm steve.
    Default Wanted: Inexpensive MC head amp or SUT
    Having just upgraded my amp to a new Rega Brio Iíd really like to make use of the built in phono stage which is apparently of very good quality. To make use of it I will need a step up device to match it with my moving coil cartridge. As I have an external MC coil stage already I donít really want to spend a great deal for a transformer or head amp, certainly sub £100. Iíve been looking at the Ortofon T-5s but they tend to be in the £100 bracket, ridiculous really when they cost under a third of that price when new.
    And they're not that great. You would do better using a good MM into the Brio.
    I'm steve.
    Donít really want to go that route as the Planar 3 is wall mounted and over 2M from the Brio and Iíd have to extend the turntable leads which would add capacitance and probably screw up the sound of a MM cartridge, MCs donít normally get affected by increased capacitance so putting an SUT or head amp in the line would be a better bet.
    As to the T-5s, a friend of mine has used a pair for over 30 years and wouldnít part with them, think he paid £20 for them.
    The T-5's are not up to much, neither is the Audio Technica AT-630, I've owned them.
    The Fidelity Research FRT-3 is in a totally different league and there's one for sale in Private Exhibitions, or was recently for £200. It's remarkably good.
    A poor (cheap) SUT just ruins the sound from MC's and is really not worth entertaining..
    "when common sense, logic and plausibility are excluded. All that remain are foolishness and lies"
    I'm steve.
    £200 is too much to fork out, if I was spending that I put another £49 to it and buy a Rega Fono MC.
    Quote Originally Posted by steve-z View Post
    I'd back the FRT-3 into Brio MM input against the Fono MC.
    What's the cart output level Steve?
    I may have one suitable.
    I'm steve.
    Iíve actually tried a Fono MC and found it to be excellent sounding and very versatile with the adjustable gain and loading settings, would have bought one 2 years ago except for something else absorbing the money (CH boiler failure )
    I'm steve.
    Itís an ATF7 and itís 0.35mv.
    I'm steve.
    Iíve had a couple of head amps in years gone bye, I had a battery operated one when I bought a Coral 777ex back in the early 80ís which was quite inexpensive (under £50) and worked well and sounded good. A few years on I had an A&R A60 amp and bought the MC head amp that A&R made to work with it and likewise that too was very good and not too costly, with the lower cost of components/ microchips these days I find it hard to understand the high cost that a lot of these devices seem to command.
