Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: My First Dispute Though eBay/Pay Pal
Hybrid View
Previous Post Previous Post   Next Post Next Post
    OM4Ti, the best ever manual focus 35mm SLR? Probably! Massive metering options and flash sync right up to 1/2000 sec (great bit of lateral thinking)!
    "Always carry a large flagon of whisky, in case of snake bite and, furthermore, always carry a small snake."
    Kevin
    [QUOTE=Mike Reed;11661]However, developing and processing options around nowadays hardly make one want to go out and shoot a roll of film. Locally I'm stuck with an expensive (£6), four day service for GLOSSY (yuk!) 7 x 5 prints. Lustre/matt a quid extra and a fortnight's wait.
    I used my film cameras only a couple (well 4) years ago. At that time, I was able to get the negs copied right to digital format and worked them in PhotoShop. The processor was Glazier's Camera in Seattle and the quality was quite good.
    I am assuming/hoping those options are still there for us die-hards.
    Sansui: G-8000, AU-20000, AU-719, TU-666, TU-717, 2 AX-7s, SE-7, SC-1110, SC-3100, SR-333, SP-2000, SP-2500, RA-500. Yamaha: YP-D71. Denon: DL-160, DVD 2910. Shure V15 Type lll. Dual: 1019. Teac: PD-710M. Senheiser: HD600. Klipsch: Forte II. KLH: Model 10. Atwater Kent AM Console. Zenith: Transoceanic. RCA: Victor. and on and on and on
    The Avatar? June Foray, voice for Rocket J Squirrel.
    Well, now that I have the camera and it is fairly close to "as described", I also got a Vivitar Series I 70-230 lens. I had this same combo back in the 70s and loved it. However, I didn't get the instruction manual for the lens and I can't seem to remember how to set it to macro. Anybody out there using this lens? And, how do you set it to mac????
    Thanks
    Is that one of the lenses that you have to move the focus or zoom beyond its normal range of movement to get it into macro?
    Is it definitely a macro lens?
    I've had series one lenses, but it's many years ago, and i can't remember either.
    Ya know? Most of them have the red line, then next to that is a yellow line and you move the focus collar beyond the normal range. I think I had that one back in the 70s. This one however just has the one distance line, then at the point closest to the camera, there are the letters M & N next to each other. I wonder if it is a true macro, or just a lens that focuses a little closer than some others. No sliding buttons or anything. I may look for another one on the Bay and sell this one.
