Here's a couple of Rega 3 point Arm spacers 6mm and 9mm thick, made from solid ebony.
Replace the multi layered and hole one that Rega supply. Also pictured.
Can be made to any thickness.
Customer fitted and sent this report to me.
"Just a little note to say that I fitted the ebony base you made to my RB303 yesterday. Listened to it last night. The improvement is massive.
I was bracing myself a little because it's a big faff for me to change the shim, as my tone arm is hard-wired in and it’s very difficult to get to the soldered joints and re-solder.* So, I didn’t much want to have to remove it again if it didn’t work. I was also expecting it to be ’too much’.
Every Rega owner should have these things. The difference is so huge. Detail as never before. It's like adding a mega cartridge, phono stage or even a new TT!
I have a superb phono stage and use a 2M Black as a cart, which isn’t bad. But I’m getting a properly high end sound now. So much more detail and less stridency. No more etched highs.*
It’s given my home-made TT a new lease of life, and will keep me happy for a couple more years while I save for a Vertere MG1 or a TMS3!
I am hugely grateful to you.
Kind regards,
Richard"
Sent from my Pixel XL using Tapatalk
