Results 1 to 10 of 19
Thread: Valve Pins
    I'm neil.
    Default Valve Pins
    Silly question - Is it advisable to clean valve pins?I've just been sorting mine and found loads I haven't used for years,I'll be giving the old ones a try as I have some quite desirable ones
    Anyway what would be recommended for cleaning said pins?
    Thanks in advance
    It's not going to do them any harm!
    PRE
    I'm neil.
    I'm Shaun.
    I've used valve amps since 1997 and have never cleaned any valve pins but I do make a habit of taking the valves out and reseating them every couple of months or so. I guess that is almost the same as cleaning them.
    I'm Gary.
    An old trick,
    is to soak the pins in coke overnight, will visibly look a lot cleaner.
    Something in the coke dissolves the mush that sticks to the pins.
    After rinsing and letting the pins air dry, always good to treat them with a contact enhancer like DeOxit.
    Dont run a valve amp anymore, but did this successfully a few times with some old NOS valves I bought.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    An old trick,
    Jeez - I missed that one, mate! So you're no longer using Nick's gorgeous hand-built creation, which you raved about so much - when did that happen, and what are you using now?
    Hi Neil,
    Quote Originally Posted by enrae8 View Post
    Thanks in advance
    Yes, gently, and as long as they're not loose, which can sometimes be the case with old valves.
    The best tool for the job, bar none (and I have lots of experience with this) is a fibreglass pen, such as this: https://www.amazon.co.uk/Fibreglass-.../dp/B003YSWJDG
    Simply rub the pins with that until they're gleaming (watching you don't get any splinters in your fingers), then clean off any excess particles with Isopropyl alcohol. Job done!
    I'm neil.
    Hi Neil,
    Cheers for that
    No worries, Neil. Defo get yourself one of those pens, as they work a treat!
    I'm Gary.
    Aye, moved on from it now Marco.
    Was a gorgeous sounding thing, but cost of ownership (at £1500ish a year for new valves) was a bit expensive to run.
    Know I could have saved money by fitting cheaper ones, tried that one time but was a false economy...that amp deserved the best.
    Anyhoo...
    Also,
    I was making changes anyway in the system going forward?
    Wanted to just enjoy the music and not worry about the kit, which is why I sold on both the Michell turntable and Nick’s superb 300B power amp (which has gone to a happy home).
    With my Michell TT I was always wondering if the spring bounce was set up right, was the arm set up properly...kind of thing.
    And not enjoying playing vinyl the was I should have been!
    And must say with the valve amp there was a bit of that too..
    ”Were the valves wearing out, is that hum I’m hearing in the background...?”
    Saving up for the valve amps final replacement (will take a couple of years), but in the meantime brought through a “stand in” Rotel power amp from the office system.
    Sounds pretty good and is a good match for my Impulse H2 horns, not close to what the valve amp was doing though.
    But hey, that’s ok. :-)
    it’s temporary, and it’s a case of one step back, two steps forward looking ahead.
    The valve amps final replacement will be endgame, in the way my P10 ‘table is.
    Just want to enjoy the music nowadays and focus less on the kit, getting there, just a couple of bits to slot in.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
