The advantages of monobloc power amplifiers are said to be, amongst other reasons, that power supplies and other components are physically separated. Two integrated amplifiers achieve this goal, up to a point, but you are back with the pre section in the same box as the power section. You could go down the route of separate pre and power amps on both sides. Of course you end up with four boxes. Why do we rarely (never?) see pre amplifiers separated this way?
I'd be a little wary of the generalised two amps is better than one arguments. There is a simple answer of "yes", but the real world question is "would two amps costing X sound better than a single amp costing 2 times X?". There, I'm not sure of the answer. On a tight budget, I'm pretty certain the answer would be no.
Personally, I'd bi-amp when I found the amp that has a sound/presentation I really like and I just want to squeeze a little more of the same, out of the system. If I wasn't happy with my current amp, I'd replace it with something else, rather than bi-amping to try and get the sound where I wanted it.
And then it's a case of choosing your budget and trusting your ears. You may well find the replacement amp that sings for you is a single one.
Rob.
Powered by crossed fingers and clenched buttocks
I'm Kevan.
Caber10
Main System:
Thorens TD160 Mk11 , SME 3009 Mk 2 improved, Stanton 681EE
2 X Quad 33/303 recently fully recapped and serviced
Quad ESL63 with Gradient SW63
Cyrus CD1
Beresford Caiman, Gator board and Dorado
Chromecast Audio
Bedroom:
Chromecast auido
Cyrus 2
Ackroyd Coniston on stands
Kitchen:
Chromecast audio
Chinese valve amp kit
Boliver model 18 stand mount speakers
Gallery
Dunlop SystemDek 2X
GramAmp2 phono stage
Beresford Bushmaster with output mods
Chromecast Audio
CELEF PE1 monitors
I'm Shaun.
I have in the past used two stereo power amps feeding into a spilt crossover so one for treble and one for bass and although it looked amazing, I can't say it revolutionised the sound quality. Of course you also require a spare pair of RCA's on the pre out.
