Results 1 to 10 of 15
Thread: Two stereo power amps for Bi-amping or two monoblocks?
    I'm Evie.
    Default Two stereo power amps for Bi-amping or two monoblocks?
    Hi,
    Realistically, is it worth bi-amping with two stereo amplifiers (one amplifier per hand side), so that there are all the advantages of avoiding cross talk, more power and only one speaker pulling on the power supply or is the money better invested in two monoblocks (one per speaker)?
    LKB
    Or a better stereo amp. It depends on the amps being considered.
    And the speakers used
    Grant .... ؠ
    OPPO BDP-103D - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2 - IFI PURIFIER 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - LEAF HD BLUETOOTH - OPPO PM-3 PLANAR, SONY H900 & NURAPHONE HEADPHONES - ZBOOK/ IFI SILENCER/WIN10 PRO/ROON - SMSL M6 DAC & IFI SILENCER - RPI 3+, DIGIONE HAT/VOLUMIO2 - EDINGDALE MK1 SPEAKERS - CABLE INC CHORD, MOGAMI, SUPRA & WIREWORLD
    **Men are not punished for their sins, but by them**Don't be such a big girl's blouse!**
    RIP Terry... "We use only the finest baby frogs, dew picked and flown from Iraq, cleansed in finest quality spring water, lightly killed, and then sealed in a succulent Swiss quintuple smooth treble cream milk chocolate envelope and lovingly frosted with glucose."
    I'm John.
    Basically as per above to replies.
    I will also add that you are better of spending your budget on ONE stereo amp/pair of Mono Blocs as you will then be buying the best you can afford. Rather than splitting the budget across two amps which will invariably be inferior in both performance and SQ.
    I'm Pete.
    Ive heard of folk using 1 stereo amp for the treble and another for the bass.
    Do you.mean two power amps? Oh aye it's in the title
    cambridge audio azur 651w power amp, novafidelity x40 music server/pre/dac, tannoy dc4t]
    , van damme blue series interconnects, van damme studio blue 4mm speaker cable, klotz mc 5000 ,klotz silver hybrid, thanks Brian, fisual hollywood optical cable,, pioneer bdp170, akg k 550
    If they can be bridged then it's a definite yes.
    If you can pick them up at a bargain price ie the same as an equivalent power/quality monobloc (to one channel of these) then I'd consider it.
    Otherwise I'd go with the "vertical biamp" option mentioned above.
    Quote Originally Posted by Lekidbongo View Post
    Hi,
    LKB
    Can be done either way, two stereo amps gives perhaps more flexibility if frequency division or perhaps 2 of the same or similar speaker is at a later point needed.
    I presently use 2x Quad 306 using one channel per amp for each loudspeaker, and there are advantages in perceived audio reproduction - in areas of stereo width and
    better ability to reproduce music.
    I'm Kevan.
    It depends how you split the signal . An active crossover between the pre amp and power amp makes a lot of difference. I am using a pair of quad33s one driving esl63 the other driving gradient subs with the gradient active crossover. Separating the signal before the amps gives each less to do and downstream passive crossovers in speakers also donít affect the signal as much.
    Caber10
    Main System:
    Thorens TD160 Mk11 , SME 3009 Mk 2 improved, Stanton 681EE
    2 X Quad 33/303 recently fully recapped and serviced
    Quad ESL63 with Gradient SW63
    Cyrus CD1
    Beresford Caiman, Gator board and Dorado
    Chromecast Audio
    Bedroom:
    Chromecast auido
    Cyrus 2
    Ackroyd Coniston on stands
    Kitchen:
    Chromecast audio
    Chinese valve amp kit
    Boliver model 18 stand mount speakers
    Gallery
    Dunlop SystemDek 2X
    GramAmp2 phono stage
    Beresford Bushmaster with output mods
    Chromecast Audio
    CELEF PE1 monitors
    In my current active system I am using 2 x Quad 405 Mk 1 (Upgraded by Fidele Audio ) for the amplification of a stacked pair of KEF 103 reference speakers . I have tried the one amp for the bass and one for treble and it works with not issues . However I do find that the sound cleans up and improves when you use a single stereo amplifier per side . If you were to replace this with monobloc amps then you would need four in total one for each side covering bass and treble to each speaker.
    With a didgital active crossover you do get the flexibility to use a powerful and controlled monobloc amplifier for the bass which needs to have lots of current . You can then use a much smaller and cheaper monobloc for the treble as there is very little stress or push made on that amplifier. Within the digital C/R you can make adjustments for different amplifier sensitivities or as with the MiniDSP DDRC24 I use it will make all the adjustments automatically through the DSP Dirac Live 2 session.
    Personally and I have no justifaction for this I prefer to have two matched amplifiers as close as possible in output and sound hence the use of as near as possible identicaly set up Quad 405,s . I know others who use a wide mixture and we all seem to get the end result to our individual satisfaction .
    One comment I would make which over my dive in to the active world is that the quality of the amplifier is of much less importance when you use a digital active c/r . Driving passive speakers through a passive c/r is much harder on the power amplifier than it is when driving individual drive units via an active network . I am sure if cost is no object using the very best amplification you can afford then the final audio quality will be improved but you may be susrprised at how little it changes compared with the very high quality results you can obtain from much more modest power amplifiers.
