Hi Barry,
If I read the op’s requirements is he thinking of adding a female to mail connector as his existing Rega lead is fixed?
I’ve never used a coaxial cable for any of my interconnects, am I missing a trick, I have always checked resistance and capacitance of cables I have used?
What’s specific around coax that makes it more suitable?
Gary
Originally Posted by
According to Goldring the recommended load capacitance for the E3 is 100-200pF, which your current phonostage + turntable leads is likely to be providing already.
Adding an additional 200pF could bring the high frequency resonance down to ~12.5kHz and into the audio band. It therefore follows that if you want to extend the turntable leads you ought to use coaxial cable having the lowest capacitance per unit length: something like a foam-dielectric 75 Ohm TV cable.
