SOLD
This is a great sounding pre and power and imo very underestimated in the U.K.
I’ve had some nice gear over the years and this beats them all but the itch has been scratched and I’ve now moved on to hybrids .
Top notch build quality
There is a very small scratch on the top of the power amp ( which I did but I don’t know how) and a small mark on the fascia .
I have recapped the SC-25 .
The knobs on the pre are not the correct duck billed one but I’m confident that they are from another Conrad Johnson preamp.
The serial number on the pre says sc-26 ?
They both operate flawlessly .
SA-250 specs .....
The SA250 is rated at 125 watts per channel into two channels. Here are some specs: Gain 25.5 dB Input Impedance 110k Ohms S/N Ratio 96 dB relative to 125 watts Dimensions: 13.25”D X 17.125”W X 4.875”H, weight 30 lbs.
SC-25 specs .....
SC25 Line-Stage Preamplifier
Gain: 21dB
Output: 7 V RMS
Phase: Phase inverting.
Response: 5 Hz to 100KHz
Signal to Noise Ratio (20Hz-20KHz): 94 dB Distortion: less than .25% THD Dimensions: 11.5"D x 17.125"W x 2.75"H Weight: 12 lbs.
Gain: 40 dB
Phono Overload: 100 mV
Equalization: within +/- .25 dB of RIAA standard
Signal to Noise Ratio (20 Hz to 20 kH): 80 dB below 10 mV input
I’m looking for SOLD for the pair.
Collection and demo from Milton Keynes or I could possibly deliver or meet for say an hours drive .
Pm if interested please
