Results 1 to 6 of 6
Thread: FS - Solid State Buffer Preamp with Balanced / Unbalanced inputs and outputs
    I'm Julian.
    Default FS - Solid State Buffer Preamp with Balanced / Unbalanced inputs and outputs
    Here for sale I have a solid state buffer which I have just opened to test full working condition and so is in new condition.
    It offers balanced / unbalanced inputs and outputs. Lots of options for use - between pre and power amps, DAC and power amp etc
    Stock photo shows components and is upgradeable but I’ve not opened it up at all. Nice solid and substantial build with brushed metal fascia.
    Here is the chinglish description -
    < This product uses advanced aluminum chassis, 30W High copper rR-core transfrormer, A grade silicon a wound without fracture! Thick gold-plated double-sided PCB (board 2MM, foil thickness 75U,), 718 resistors, fever capacitors, gold-platedXLR (Cannon Block), RCA, Texas 5532 new op amps. Gilded left on board IC socket, users can easily upgrade the op amp.
    Features: Can be used without balanced output interface DAC, CD, sound cards, and other pre-installation of balanced input and output, sound immediately upgrade several grades, the sound field is very open and elegant, but also significantly enhance the resolving power! >
    I have all the original packing so can send safely.
    £75 collected or £79 delivered, PPG or BT, no offers please.
    These are only available to import from HK or China, but of course buying this unit means you will avoid paying any VAT or import duty.
    Sonore Rendu - Cambridge Audio Edge W - Sonus Faber Venere 2.5
    I'm Julian.
    Still available!
    I'm Julian.
    Anyone like to make me a good offer?
    I'm Rob.
    Is there any information online about this? Do you have a link to the seller?
    https://youtu.be/ZCBe7-6rw4M
    PM sent
    I'm Julian.
    This is now sold.
