Results 1 to 10 of 13
Thread: Open plan living space speakers.
    I'm Simon.
    Default Open plan living space speakers.
    We live in a open plan living space 8m x 8m - (for want of a better phrase) a with a vaulted ceiling.
    My current set up is a simple cyrus3i and psx-r, beresford Caiman II DAC for digital pre for TV and stream duties, and TT with a Gram Amp2, I swap in and out...mostly listen to vinyl myself.
    I'm currently favouring a set of vintage Goodmans Magnums, (these also work as furniture) and whilst these are good vintage speakers, I have yearning to try something else.
    I need something to fill the room but the acoustics are quite challenging with quite a bit of glass, a tilled floor, and high ceiling. Whist I have the space, I'm not looking for something that needs to be half way across the room or miles from the nearest window to get some bottom end.
    So floorstanders or stand mount? Not looking to upgrade the Cyrus kit, so something Cyrus friendly.
    Just looking for some inspiration really.
    IMF TLS50 or TLS80?
    They are quite laid back so shouldn't be a problem in a highly reflective room. No need for stands. Cyrus amp won't be all shouty through them.
    Or KEF 104AB - something along those lines.
    I'm Adrian.
    Quote Originally Posted by Ninety4degrees View Post
    I have gone (and still am) through the same journey. My listening room is about 8x9 meters with 5m ceilings and lots of glass. My tannoys did nothing in this space, they couldn't energise it resulting in almost zero bass. It's full of soft furnishings, palms etc to soften up reflections and that works great. But I couldn't live with nothing below 60hz.
    On a whim I swapped my old style ANe's in, close to the corners and near the wall and bam! Bass - in fact I can tune what I hear by adjusting the distance of my listening sofa, closer emphasises mid bass, further back deep bass - it's pretty impressive. But my ANe's are the old style, not the, modern lightweight ply version.
    Now I want to keep that aspect but improve on transparency and have been looking around at speakers - but my god its a gamble as no demo can mimick my room.
    There's a pair of old stylr ANe's for sale on here right now.
    Sent from my Aquaris X Pro using Tapatalk
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I'm Andre.
    The reverse here Adrian im trying to Subdue the Bass response in the living room. Why i opted for tiny speakers in a 4.6 mtr Living room.
    You might try some full range ones I found mine were good with lower base. Mind you I designed cabs that way. You got bass but without reverb causing issues.
    I'm inthescottishmafia.
    Open Baffles perhaps.
    Hunter S Thompson
    I'm Simon.
    Thanks all for the responses - certainly food for thought there.
    Transmission Line? - PMC perhaps an option? May be suitable for the Cyrus!
    Full Range or open baffle not something I'd considered, certainly not considered kit or DIY....(strokes chin)
    I'm Adrian.
    If its boomy bass I would also pay attention to furniture and sofas etc. They can have a dramatic effect. Try moving things from another room into the space and play for a day.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm Neil.
    Rugs on the floor, sound absorbing items and a warmer fuller set up to work against the cold, bright echo filled room.
    Regards Neil
    You need some absorbent in the room otherwise you will never get a decent sound, no matter the equipment.
