Results 1 to 10 of 10
Thread: ChordOhmic fluid
    I'm Robert.
    Default ChordOhmic fluid
    My System:
    CDP - Pioneer PD-91
    I'm Dennis.
    Chord has a good reputation, so the probability of this being foo is smaller than is very often the case.
    I'm John.
    Give me strength!
    Sent by me using an appendage
    SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    Not bad for a bottle of contact cleaner.
    Whatever happened to 'Tweek' contact cleaner?
    I'm Adrian.
    Quote Originally Posted by robbiegong View Post
    really🤪🤪
    I'm Robert.
    Looks like Chord re-branded it, included some 'science' spiel, and added a couple of noughts...
    My System:
    CDP - Pioneer PD-91
    I'm Rohan.
    It may be good- but what a ridiculous price. I hate this kind of nonsense with a passion.
    Apparently these fluids only work well if both contact metals are identical in chemical composition. ie pure silver and pure silver.
    If there is a mismatch then chemical reactions can occur. I have read of black gunge at the interface after a period of time.
    This applies equally to a mismatch in the quality of (say gold) plating.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    Ah - but is it the original snake oil? Maybe it has provenance!
    Dave
