Looking to invest in a new power cable for my Auris dac. Standard UK plug and kettle lead required. 1 metre minimum. Up to about £40. Would consider a diy option if anyone has some good advice?
Cheers
Kev
Cheers
Kev
Kev.
I have a few exces that could fit the Bill . Kimber , Isotek and mark grant . Drop me a message if your interested .
If you wanted to DIY supra 1.5 mains and plugs will be doable for sub £40 this will give you a shielded mains which may help if your cable runs are constricted. You could do better in the used market though.
I can let this go for £40 +£4 p&p
https://www.ebay.co.uk/itm/164091946...84.m1555.l2649
retails at about £120
Got couple 1m lengths of living voice mains, very stiff copper, 12 years old I think. Made by Kevin, looks bit diy.
Now sorted, thanks to all for kind offers.
Kev.
