Looking for a pair of cheap but good quality over the ear headphones. Vintage fine but must work without distortion.
Cheers
Adey
Sent from my Aquaris X Pro using Tapatalk
Cheers
Adey
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
How much are you looking to spend?
Are they purely for home use?
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Probably an idea to (a) state your budget range and (b) which can amp you'll be using with them, and, depending on (b), whether you prefer low (50 ohms ish) or high (300 ohms+) impedance. Other aspects like cord length and comfort/weight limitations, whether boxed, etc. might narrow down what people may offer. Have a bump. Personally I'd recommend something around the Sennheiser 600/650 mark (£125 to £225 used) but Beyer and others may be viable options. If around £500, there are some choice cans (Focal, e,g.) but your sources and amplification need to warrant this level.
Sorted.
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
