Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: FLAC for Dummies
    I'm Rick.
    Quote Originally Posted by Paul-H View Post
    Just did a check on one track and the results are
    WAV 56Mb 1411kbps
    FLAC 56MB 1415Kbps, that using the Uncompressed setting and both at 16bit 2 Channel 44100 Hz
    So for that one track the result was almost identical certainly in the size department.
    Paul
    Aha. Yes, that would produce the same results - an uncompressed FLAC is identical to a WAV. If you have lots of free disk space then I wouldn't worry about it... If you want to reduce the file size, you can try default compression settings.
    56mb with be file size on disk.
