Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Phonostage to headphone amp: RCA Y-splitters OR RCA swithbox OR IntAmp pre-out loop?
    If you’re using the pre-out from the amp to headphone amp then surely that will present every input to the headphones?
    Unless I’m missing something it’s not much of a pre-out
    As it happens I have a passive in front of my integrated for this very purpose. It has two direct outs as well as volume controlled outputs so one of the directs goes to my headphone amp.
    I'm Daniel.
    Correct, the pre-out will get any input into the integrated amp over to headphone amp. As I now have a separate phono amp, I would like to be able to listen to phono with headphones without going through integrated amp, so that I do not have to turn the sub on/off every time.
    Something just clicked! I guess that is an advantage of having separate pre-amp and power amp. Then I can have power amp off, but pre-amp on with all input sources going every which way and no need to fiddle with sub. Unfortunately, I'll have to wait a bit with looking into a dedicated pre-amp. Just shelled out a bundle for the TT set-up.
    Yeah I had a look at the manual, that pre out isn’t going to do what you want is it....
    I'm Andre.
    Daniel do you think it might be better if you considered dumping the Rotel amp? Having no tape loop is a pain
    I'm Daniel.
    Hi Andre, now that I finally get why having separate pre and power amp can be of value, I consider changing the amp configuration. I guess I could use the existing Rotel as a poweramp for a new, dedicated pre-amp. Or trade in the Rotel for a pre/power combo. Hmm, lots of questions. Will take a while to sort that out, and I just shelled out a bunch for the TT rig. For the time being, I think the RCA passive pre-amp/switch will be the least painful. Not sure which route I would want to go re SS vs tubes, and digital in/out/DAC/ADC considerations. I might lean towards something tuby, needs to have some digital capabilities, and I certainly will want to listen to them, won't buy them from specs.
    I'm Adrian.
    Quote Originally Posted by Exophile View Post
    Daniel, having owned a Tisbury which I just used as a pure passive into a pair of mono blocks it should work for your with the Turntable.
    If I recall correctly there are 3 inputs and 2 outs, one output is the switchable one and the second is the bypass/loop.
    So if you connect the turntable to one of the switchable inputs and the switchable output to the appropriate input on the amplifier this will be for normal speaker listening. If you configure the Tisbury so the other output is permanently on then from there you go to your head phone amp.
    It should work. You can obviously connect two other devices to the other 2 inputs on the Tisbury, you just need to ensure their output voltage is not too high for the inputs on either amplifier(main amp or headphone amp).
    I hope that makes some sense.
    I'm Daniel.
    Adrian, thanks for the explanations. I think I will rather reverse it, so use the Tisbury tape out as my in from the phono stage, then plug the headphone amp into Tisbury input 1, the Rotel into Tisbury input 2. That way I can actively switch the output (with the Tisbury input selector) to where I want the signal to go. According to Tisbury, that should work. Soon enough I'll know. Recabling is really no big deal. Most likely I will try all sorts of combos to see what works best.
