Results 1 to 10 of 20
Thread: Studio Monitor Speakers
    I'm Lee.
    Default Studio Monitor Speakers
    Hi everyone,
    This one may be a bit left field but I was wondering if anyone has used near field active monitors for normal listening.
    I been watching some YouTube channels and speakers like the Yamaha HS series, HS7s,
    or JBL306P series keep coming up.
    My understanding is that Studio monitoring speakers have a flat EQ curve.
    If you have can you say what your experience has been and any recommendations or ones to avoid.
    Thanks
    Lee
    It’s about the music
    70s Retro Yamaha YP800TT, CA1000Mk2, CT1010
    I jave a set of Klark Teknik active monitors. Bloody expensive back in the day but absolute quality with an amp (100w) for each driver.
    Sent from my SM-G930F using Tapatalk
    Main system: Sony TTS8000; AT1010; Audio Technica Art1; The Lentek; Cambridge 851n, Yamaha NS1000.
    System 2 - SBT; Technics SH-X1000 DAC; Denon PMA-850
    I'm Andre.
    I have a pair of those Yammi's. They are ok, they weight a ton & finished very nicely.. Ive since listen to the present Mackie MR & i prefer em..
    https://mackie.com/products/mr-series-studio-monitors
    I'm Andre.
    https://www.gearsourceeurope.com/cat...tudio-monitors
    Only one set for sale in Europe at 2k (Euros). They are very good.
    I'm sure hifilover had some JBLs like those for sale last year. Might be worth contacting him
    I'm Dennis.
    Quote Originally Posted by Made in 1968 View Post
    What an annoying egotistical twat.
    I'm Lee.
    Hi,
    How are you using the Mackie MR? Are you using them for near field monitoring or sitting a distance away and listening to music? How would you explain the difference between the Mackies and Yamaha ?
    Thanks
    I'm Andre.
    I find the yammi's a bit bright..
    They are sat on a studio desk near field.
    https://www.youtube.com/watch?v=_Vexqyg1pCg
    I'm Lee.
    What’s the view on 6” or 8” driver? Which one would be best in a two way speaker?
    The only 8” speaker I had was a Monitor Audio RS but it didn’t really work in my room and I have moved now.
    Am I right I thinking you lose out on the mid range but gain in the base with an 8” driver?
    Thanks
