Sonos play 5, black, first generation, in excellent condition and perfect working order, boxed with power lead and booklet.
£165
I'm Simon.
£165
I'm glenn.
Is this one of the models that Sonos will no longer release new uosates for after may?
I'm Simon.
I'm glenn.
I asked the question as i was interested in buying the speaker, I was aware of some of the sonos stuff not being supported but did not know if this was one of them.
Thanks for answering my query
I'm stuart.
Since the OP hasn't fully answered whether it'll work or not:
It will continue to work after May but there will be no new updates. If you plan to use this with newer Sonos products then you will not be able to update the newer products either.
Alternatively, you can isolate the older, affected devices and run them separate to your newer speakers - ie. run two independently connected zones in your home rather than one. The older devices connected to each other in one, the unaffected devices as another. That way, your newer devices will get the latest updates.
Garrard 401, Jelco 750 with Shuggie, Ortofon 2M Black / ZYX Yatra 100, Project Phono RS with Sigma22 Linear PS, RPi3 + DigiOne + Linear PS, RPi3/1Tb SSD with PiCorePlayer + Linear PS, Perreaux Eloquence 250i 40th Anniversary with ES9038Pro DAC, DCG3 Pre-Amp, Neurochrome 8x2 Pre-Amp, Neurochrome 686 Power amp, Benchmark DAC2 HGC, Primare V25 CD player, Monitor Audio PL300, Sjostrom DCT03 DC Blocker.
