Results 1 to 3 of 3
Thread: Recommend a hdmi ARC compatible cable
    Default Recommend a hdmi ARC compatible cable
    Hi,as the title suggests, 1m in length would be fine and £10 ish if possible, cheers Jim
    I'm Jerry.
    I have two of these:
    https://www.amazon.co.uk/27Gbps-High...fsclp_pl_dp_15
    Great quality and fully support HDR. If you havent tried High Dynamic Range it transforms picture quality, especially extreme contrasts-looking out from a cave into bright sunlight for example.
    Well worth the extra over your budget.
    Jerry
    Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
    Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
    AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
    Quote Originally Posted by Covenant View Post
    Ta Jerry, that's not silly money
