I'm Ben.
I'm Andre.
Well people seem to think they can make these things sound modern.. I wouldnt swap the tweeters personally but thats me, i learned my lesson the hard way about not keeping stuff original..
I'm Ben.
What do you think about putting the MD500 for the 66 into the 44?
I'm with you on copper. I used this Van Damme in the car and for the cinema system - http://www.van-damme.com/vandamme_pr...speaker-cable/ Too modern?
i would wait for a pair of 66's to turn up,they just got that speaker right on the money.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm Andre.
Ben
You dont need cable as heavy as that. Just like for like none descript hook up wire the same guage will be fine if you need to change it..
Can i ask are they later veneered baffle boards or the early black painted ones?
I'm Ben.
Early black painted ones.
I'm Ben.
https://www.autoelectricsupplies.co....66/category/11
Cheap and will the job just fine. Or you could just buy some solid core 1mm copper from your local DIY store.
I'm Andre.
With the circular terminal pod. These should have tiny coloured thumb screw posts. If you feel the need to swap these or have been swapped for ugly modern ones. The ones in the link below should be good enough & look ok as a replacement with some reliable nice plating & cheap, Those coloured isolators can be removed but these are small enough
https://www.ebay.co.uk/itm/Nickle-pl...53.m1438.l2649
