The Vortexbox software has been around for a good number of years now, I have been using it pretty much since it was first released. It is a simple fast ripping solution for CD’s and DVD’s which mostly works very well.
However. I no longer use the Vortexbox CD ripper to rip any new CD’s as I have had problems in the past with some older classical music CD’s, in that the file names the ripper generates are too long for a Windows system and sometimes contain cryllic characters from eastern block recordings, consequently the files cannot be copied from one PC to another under Windows.
Of course this is not a problem if you only use the Vortexbox backup utility, or you use another Linux based computer to backup your files.
I rip any new CD’s I buy now using the DBpoweramp software which I save directly to the Vortexbox music folder.
