Just plugged the Croft micro back in after using a JVC ax z 1010 for a few months, and its not working, sound is distorted, using it with a 909, replaced the croft pre with a cheapy passive and that works, so fault is defo in the Croft.
Check the fuse, if not it's a valve.
I believe there is one for + and one for -.
I'm ahto.
it's mostly been the fuses in my experience. a blown fuse means heavy distortion.
they're at the back.
QUOTE=Mikeandvan;1153389]Thanks Dave, which fuse do I check? And how can I tell which valve is playing up?[/QUOTE]
Lenco L75 in a very heavy plinth /Hadcock 228 /London Decca Blue /Croft SMA IV Octal with separate 2020 PSU/ Croft 7R monos /Harbeth SHL5
Fletcher .3 /Hadcock 228 / Denon 103R/ Croft HeadAmp /Croft Mega Micro II (2015) /Croft Series 5 MkIi /Markaudio SOTA Cesti B
Leak Troughline III GTA / Vecteur D-2.2 / Wadia 121 / Katana, Isolator & RPi /RFC & AntiCable
I'm Allen.
Depending on age send it off to Glen for a dose of looking at
Tried again and was working, then nothing, was using a Graham slee phone stage through line 1, changed to line 2 all fine. So what's up with line 1?
