Originally Posted by
RobbieGong
Hows it going Adrian,
How you finding the Sony's presentation ?
That's a more complex question than you may think.
The Sony has 3 types of output, balanced direct from DACs, direct single ended, and variable single ended.
Its thought that all 3 impact on the sound with some people preferring the direct single ended as being the sweet spot and most dismissive of the variable as audibly inferior.
I lived with it (when playing up so not as much listening as I'd have liked) via direct single ended and would describe the sound as analogue, airy, liquid, focused with reasonable depth and very good sound stage. Vocals were beautifully rendered. This was with my Luxman AT3000 TVC.
I am now using the variable single ended (the luxman has departed to a new home) and it is a different story. The sound stage is congested, multitracks fight for attention. Not in the same league. But it has power, energy, prodigious bass. Away from the speakers it sounds huge and extremely good - but sit down between the speakers and its horrible. This is the exact opposite of my old vinyl rig. From afar nothing special, but sit down and you were transported to a different space. Yes I was using exceptionally good gear - but the Sony on direct single ended with the luxman got pretty close. The cheap alps blue pot, the complexity of the circuit and amplification are screwing the sound, which after living with AVC/TVCs transparency and zero congestion is unacceptable.
This has got me thinking of 2 things and put me in a dilemma. First how would it sound using the balanced, and should I continue that to the audio research 75 which is wired for balanced. Of course I'd like to try but that will necessitate new interconnects.
I need to get a preamp and am torn between wanting the abilities of a TVC or going active to maintain that energy and balls.
An active pre is better with the ref 75, I knew it when I bought it, but I am not sure I could get the level of a TVC plus an active in my price range at the moment. I could get hold of an Audio Research ls9 which has good reviews, would suit the amp but is 30 years old. I'm aware of very expensive TVC/active solutions but that's out of my league.
I'm not looking to replace the luxmans performance, that in my experience isn't possible, and will be happy to step down the ladder a rung, maybe Slagles or Tribute which I lived very happily with before the Truth and the the Luxman.
The CD is playing fine at the moment all tracks. It still hates a slight scratch and CDs need to be pristine which is a bit of a pain.
I need extended listening with a pre I trust to be transparent before I can pass serious judgement.. Trying balanced also. If I'm still not happy and it's running fine then an external DAC will lead me down a new rabbit hole I'd prefer not to go down. I'm hoping that sorting the pre will take me back to what I was hearing before the luxman left.
Sent from my Aquaris X Pro using Tapatalk
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
