No wonder I was having problems when I tried one on my record deck.
I'm Dominic.
This is where accurate diagnosis saves time and effort.
If a player plays the majority of a disc without skips or jumps then the laser is working perfectly, so leave it alone.
If it baulks from track 10 onwards then it is the rails or sled that has contamination of some sort restricting movement. Take a cotton bud with a few drops of isopropyl alcohol and wipe the rails to remove any sticky residue, then a soft lint free cloth to clean the rails, paying particular attention where the sled body edges meet the rails as dust and fluff accumulates there. Finally just one drop of light oil on a cotton bud to lubricate the rails - no more than one drop otherwise dust will quickly stick and you are back to square one in a short time
CD player = Marantz CD6006
DAC/pre = Rotel RC 1572
Power amp = ADA PF201
Speaks = Quadral Chromium Style 6
Yes, I reckon that was the issue. Will give it a thorough going over. I really did think I was going to be left with a rather beautiful brick!
Having heard some of the newer players I am very impressed with this 30 year old Sony.
Sent from my Aquaris X Pro using Tapatalk
Technics SP10 mk2
Miyajima Shilabe cart
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Audio Note ANe-SPX speakers
Hope it all works out Adrian, hifi can be gut wrenching and drive us to despair sometimes, trust me i know. Let us know how it goes.
Btw - We have similar taste, as in a liking for great vintage gear ie: Both SP-10 MK2 and then Pioneer PD-91 cdp - me, Sony X777ES cdp - you
My System:
CDP - Pioneer PD-91
Yes I have a thing for classic Japanese masterpieces, the sp10 is in my opinion still unrivaled as a disk spinner for all the right reasons. Likewise the Luxman AT3000 sits right up there with the creme de la creme. The Vida will I believe one day be a classic. The Sony embodies what I look for, superb craftsmanship and soul, something I value over hyper detail any day.
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Top man, and absolutely Adrian (You're a man of taste with some sweet kit, if I may say) and yes the Vida will be a classic as it was always special from birth so in my view already is one
Been listening to some fave cd's courtesy of my Pioneer PD-91 this evening, powered by Sansui AU a707DR and can only say, lovin' it big time !
Had the PD-91 sat on hifi rack looking pretty for a good few years plus and only lately have I given it a proper run out and listen Addiction to vinyl to blame for that.
Now when I'm finally in receipt of the Yannis tonearm cable I'm awaiting, is when the fun will really start, when I at last can start to evaluate my SP-10 which I'm in no doubt is gonna be a thriller !!
My System:
CDP - Pioneer PD-91
Hope you've now sorted the problem Adrian... nice one ..
I've never owned anything "classic Japanese" unless the Pioneer A-400 amp qualifies... however I've always admired the well made Japanese stuff...
Bev
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Holy crap I need help with this sony. I don't understand. The laser housing for some reason keeps jamming towards the end of a CD, so will always stop and go crazy. If I push it back to normal position (closest clamp) it will read TOC in less than 1 second and plays until track 13 (depends on previous track lengths) then f*ucks up. It is obviously meeting or causing resistance as it moves outward to the periphery of the disk.
I've oiled the guiderail and the ribbon cable doesn't impede anything... Could the servo be failing or a cap on the servo power supply. I really feel as though I'm cursed with HiFi at the moment and just want bloody music.
Help!
Adey
Technics SP10 mk2
Hashimoto HM-X SUT
The Truth linestage
Cary 805c SET amps
Hi Adrian
Not sure how Sony originally set up your model of Sony from CD/Laser sled point of view, but my experience with a Meridian 508 player may help to explain your issues.
The Meridian 506 and 508 both use a particular and very good Philips CD mechanism, this when built new was greased with a grease designed for plastics, the laser drive mechanism and worm wheel both being plastic. It is crucial that this mechanism moves freely so the laser can position and track accurately, if not the CD player will do all sorts of things and eventually not play at all and complain of no CD in the unit. All Meridian CD players eventually fail due to the same issue, the grease that Philips used goes hard over the years, and it can be so bad that the mechanism can get damaged, but not always. So the solution is very carefully clean it removing all old grease and then apply plastic grease that does not go hard, if this does not work then it is a new sled and laser I am afraid.
So it maybe that your CD mechanism is suffering from the same problem if Sony were guilty of using the same type of grease when it was made. I would carefully get to the sled determine if you can easily remove it from the unit so you can clean and re-grease, or if it has to be done in situ. I would check online to see if you can find any others who have had similar issues with this unit first, there is usually something out then, have you searched on Youtube for Sony CD player issues?
I hope that helps a bit.
Adrian
