Hi
I have a pair of Eden on the way too cheap not to have 😁😁 but also want a pair of A14s but they have rotted foam surround does anyone know where I can find a 6.5 replacement?
Cheers
Hi
Cheers
Receiver
Marantz 2225
CD Transport & DAC & PSU
Turntable
KAM DDX 1000 with Goldring G800 Cartridge
Loudspeakers
Mordaunt Short M10
I'm Andre.
https://www.ebay.co.uk/i/36268474151...RoCJ2UQAvD_BwE
Just buy a PP3 battery too
Receiver
Marantz 2225
Turntable
Loudspeakers
Mordaunt Short M10
I'm Andre.
No you cant just shove anything on. Measure the overall diameter & internal diameter + the profile.. Ask him for a pair to those diamensions..
14L! Do yo mean A14L?
From the royd site they need 6.5 diameter they are MK1 14L and
When I view them next will get full spec
Receiver
Marantz 2225
Turntable
Loudspeakers
Mordaunt Short M10
I'm Andre.
Yeh A14L are the first ones. The should have a giant port on the back, i think the later ones were sealed enclosure.. Not positive on that tho..
I'm Andre.
Theese might do if the measuremets are the same
https://www.simplyspeakers.com/missi...t-fsk-6.5.html
I'm Andre.
No need to take of the dust cap if you dont want to. Just use a PP3 battery to keep the coil centralised..
