Originally Posted by
Patrick Dixon
As an example of unintended consequences I have seen people justifying that the benefits of 24 bit digital audio cannot possibly be heard because the extra resolution is below the SNR ratio of the reproducing equipment :-(
Not the best counter example, seeing as no-one can hear the difference when put to the test, and bit rate relates to dynamic range, it has nothing to do with frequency response in any case.
