Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Fitting Nima tonearm
    Default Fitting Nima tonearm
    Just got my TT back from NAS, they fitted the Nima collar into the armboard for me, this Nima feels flimsy as hell! Anyway, I don't have a alignment gauge for the Nima, how do I fit it correctly? Or do I just use a rega one? Must be somewhere you can download these, I wanna hear my new tonearm asap!
    Set ups on you tube I think
    I'm Karl.
    Rega one will be fine as its the same geometry. One thing i found helped the nima lots was the tiger paw skale counterweight. It brought improvements to the sound quality but also having the weight closer to the pivot helped to make it feel sturdier. Its a very fine arm. Add a yannis tome cable to the party over the stock one and its a force to be reckoned with. I loved mine
    CTC Classic 301 , SPH bearing and Hanze Hifi HAT CPS-2 all analogue power supply / Tenuto Mk2 mat / custom Panzerholz and Kewasinga articulating plinth / Track audio isolation feet / Reed tonearm / Audio Technica ART 9 / 2 box BigBottle mk3 phonostage with Clarity cap CMR and NOS Telefunkens valves / Croft 25R preamp with upgraded 12BH7A line stage and NOS 1956 RCA valves / Croft 7R monoblocks with NOS 56 RCA valves/ Dynaudio Contour 30i speakers / Spotfire interconnects and speaker cables / Merlin Scorpion mains block / Rhodium mains cables / Marantz CD DAC /
    I'm Jonathan.
    Roksan supply a setup template for setting the overhang and the specs/setup guide are on their website. It is easy to set up but my shaky hands make handling the ‘wobbly’ arm fun!
    Wonder how the tonearm headshell with its slanted cart setting affects alignment?
    IMG_20191222_000854860 by Mike Van, on Flickr
    Quote Originally Posted by Bigbird View Post
    Got a Yannis on the way! (coppercord, £60).
    Same as if the headshell itself was offset, one or the other....
    I had never seen a Nima headshell before this thread. I don´t remember reading any criticism for using acrylic in such a vital position whereas using it for a sub-chassis received no end of hoots in its day and in general most seem to think acrylic is a no-no, cold and steriñle sounding when compared to more generally used ( and supposedly) expensive and difficult to machine materials.
    Makes you think.
    While very grateful to many forum comments which have helped me no end over the years, I tend to switch off when it comes to trying to understand justification for things via amateur engineering classes. I reckon the most truly useful suggestion in hi-fi is "go ahead, suck it and see" - you never know.
    The lovely people at Monitor audio sent me a free protractor for the Nima. How the hell do I use it?
    2020-01-14_11-36-33 by Mike Van, on Flickr
