Results 1 to 10 of 17
Thread: Nu Force 9v3 Mono Recommendations
    I'm brian.
    Default Nu Force 9v3 Mono Recommendations
    So, everyday can be different and exciting ( read costly ) on eBay and this was certainly no different. So I need a nice pre amp to match my Nuforce 9v3 mono blocks
    that I was fortunate enough to win on the auction site recently. These are class D amps, being genuine analog switching amplifiers capable of driving low impedance loads ( 320 watts @ 2 ohms )
    I know its unlikely anyone, or at least not many would have tried these monos but any input would be appreciated on ideas for a pre amp. Budget would be around 400 ish, but that could well
    end up stretching like a rubber band me thinks !. Thanks for looking.
    I'm Phil.
    ?? https://www.schiit.co.uk/Saga_S
    certainly found the saga to be very able for the money . I will be getting out the schitt freya to use with my class D monoblocks soon . however the bel canto pre 3 [vbs ] is an exceptional match with them so it may not be too soon
    Eric Bibb
    I'm brian.
    Thanks Phil. Sort of suggestion I was looking for. Always hard to beat a bit of Schiit !
    The quad vena 2 is an excellent amp that I use in pre mode.
    Has remote as well. Even Bluetooth should you wish.
    Been very happy with sound. Also handy to have a small size integrated as a back up
    I'm John.
    I have a black Primare Pre 30 which is very nice and fully remote controlled if it would interest you Brian?
    I’d need £500 plus postage for it but I think it’s well worth it and should hold its value well.
    Very well built piece of kit.
    Edit: It’s fully balanced input to output but offers RCA connections too!
    Hi Brian,
    You need a pre with balanced out to max out those Class D amps
    David
    I'm brian.
    Thanks David. Have you ever worked on or no anything about these nuforce amps ?. Thanks for the replies everybody. Something to ponder over in the days/ wks to come.
    Hi Brian,
    I have-a while back now-and they definitely did better with a balanced out pre
    David
    Sent from my ONEPLUS A5000 using Tapatalk
    I'm brian.
    Thanks David. Yes, the reviews and the guy I bought them off say they can be sensitive to cable swapping. Save up for a balanced output pre then lol
    I'm Phil.
    the schiit freya solid state has balanced out and just slightly above your budget
    https://www.schiit.co.uk/preamps/Freya%20S
    Eric Bibb
