Looking for preferably a valve integrated 45, 2A3 or el84, or whatever else you may have for my consideration. Budget £2k dependent on what is on offer
Check out John wood Paul, you’d get a good speck for that budget
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Can't find a website just a used 6L6, is he still in business.
If you want a classic vintage integrated valve amp at a lot less than your budget I have a Scott 299D and an Armstrong HG88 Mk3.
try here, http://jwoodaudio.com/
your very welcome to hear mine if you like
My System
John Wood KT88 Amp.
Try this out, lovely amp, I should have kept mine, https://www.ebay.co.uk/itm/AUDIO-INN...UAAOSwXXBd3GKc
Get these guys to check it out and possibly upgrade it.
I'm Drew.
I'd contact Nick Gorham- ha can build one to your own spec...
I'm keith.
I'd be buying an Allnic with that budget
They only come up occasionally secondhand, but well worth the wait.
The older 300B would be within budget, think they also do an EL84 now.
Good hunting.
